From all the past threads it appears that most coatings can not be removed, they must be polished off and that requires re figuring the objective and then re coating. This is cost prohibitive unless it is a rare collectors item I would think. I have heard that some early coatings were removable, but this is for old scopes not anything current or newer.
Typically, achromats are single coated with MgF2, which increases the transmission by 3% per surface. So, even if the coating looks terrible, if the wear and tear is only on the outer exposed surface, the transmission loss is insignificant.
A more important problem is the phase shift difference between rays that pass through 1/4 wave thick coating and those that don't, where it's missing. You don't really want an extra 1/4 wave error added to any fine lens. For that reason, if a lot of the coating is gone, say 25%, (which would look outrageously horrible under a bright light) best-resolution has been slightly compromised.
The up side is, if that much coating came off due to natural causes, it can't have been that good in the first place, and it probably will not require abrasives to remove the rest.
Perhaps contact these folks http://www.majestic-coatings.com/
I have in 2 cases been able to improve or remove degraded coatings with ammonia-based lens cleaners like Kodak Lens Cleaner and Residual Oil Remover. They removed the degraded and cloudy parts of the coating, leaving either clean glass or traces of good coating. The method was same as lens cleaning, just use them on a cotton ball, but with slight pressure and many repetitions. Watch progress carefully and stop when there is no more improvement.
In the one case where I had a lens coating professionally polished off and re-coated the result was not entirely satisfactory. The result looks good cosmetically, but on an optical bench with knife edge test you can see the surface is fairly rough, and in the field planetary contrast is slightly impared. I think they polished until the old coating was gone, but it really should have been fully re-figured after that. I presume the glass and coating polished off at different rates, so the net result had lots of random hills and valleys. (It was not Majestic, but a different company.)
