Hi all,
I got a bit more time at the 127ED tonight and can give a bit more info. The Go-To works very well and the Polar Alignment Scope is quite handy. The stock finder sucks, but I have a new Sellarvue Right Angle Correct Image 50W2 coming from Anacortes so that should help.
I did a few star tests and the optics look textbook perfect. Very good consistant difraction rings on each side of focus. No turned edge or correction problems that I could detect.
Color on Vega was just a slight tinge of blue around it, not distracting or particularly noticeable. It is there, but it is much better than the AR5 and on stars less bright, I could not detect it.
The scope works well and brings in the DSO fairly well for light polution and a near full Moon. It can not compete with a 10" Dob, but it is about as nice as the 8" SCT that I had.
The tube is great looking and not too heavy at 14.5 lbs. The mount is solid and very quick to slew to objects. The electric focuser works very well and has 4 speeds which makes it nice to use.
It would be nice if they put stars in by name, but they are by a number system.
The strangest thing was that they set GMT at +7 instead of -7 for Pacific Daylight Time. I do not understand why they have that backwards, but you have to put it in incorectly or it does not know where anything is located.
The quality overall is quite good it seems. I am pretty impressed so far. It is not a true APO, but if it were it would have cost a small fortune too.
