Gary Taylor
M27 - Dumbell Nebula
Re: Safety undercuts
Started by jonisaacs, 11/10/2005 11:29AM
Posted 11/10/2005 11:29AM Opening Post
I tend to dislike the "safety undercuts" but it does depend on the focuser/diagonal in use. In a TV Everbright with a set screw, they seem to work nicely.
One problem I haven't seen mentioned is that in a focuser/diagonal with that uses a non-captured screw, I find that I sometimes end up backing the screw out too far and dropping it. With a smooth sided eyepiece, it only takes a small twist and the eyepiece is can be removed, with the undercut eyepiece, it takes several turns and can result in the losing the screw.
jon
Posted 11/10/2005 05:09PM | Edited 11/10/2005 05:09PM #1
Jon,
I have the same problem with the Feather Touch. Some times I have to loosen the set screw so much it falls out. :C
