Mark Eby
M33 Triangulum Galaxy
Telrad Base Falls Off-Need Help!
Started by Jud, 08/20/2006 02:18PM
Posted 08/20/2006 02:18PM Opening Post
My Telrad base has detached from the adhesive strips and will not stay put. Does anyone have advice to resecure the base. Seems the base has a very small surface area to contact the adhesive. Right now I am considering duct tape wink.
I Yam What I Yam!
Posted 08/20/2006 10:25PM #1
You can by good 3m foam tape and replace the tape. I have used it with good results.
I have mine attached with screws or other means however, on the new scope.
Posted 08/23/2006 01:17PM #2
Judson,
If you want more details on the 3M tape, you can go to there website and look under "VHB (Very High Bond) Adhesive tape". They make a slew of versions in many widths and thicknesses. If there is a 3M distributor nearby you can call them up and request a sample. They make samples available to potential users free, or at least they have up until recently.
Regards,
Mike Mandall
Posted 08/24/2006 03:39AM #3
Judson,
I don't know if it will be usefull to your application. There is a company called GCS Astronomical that sells a replacement lainding pad for the telrad. The item is called a RadPad and they work rather well. You might want to look into it.
Jay
Posted 08/24/2006 05:05AM #4
Though not as elegant as Ivan's setup, I found that a plywood block
taped onto the scope structure worked for me, too.
Hasn't fallen off yet! wink
Linton
(60" Hale scope - Mt. Wilson) 8)
lintonius's attachment for post 106591
Posted 08/28/2006 04:52PM #5
Another great idea! Thanks!
I Yam What I Yam!
