Mark Eby
M33 Triangulum Galaxy
Orion focuser modification
Started by fblue, 12/30/2005 12:41AM
Posted 12/30/2005 12:41AM | Edited 12/30/2005 12:45AM Opening Post
Ok, there were a few inquiries as to how I modified the Orion finder to eliminate the slop in the barrel. So I made a pictorial guide to the modification.
This requires that you get a piece of 3/16" thick Teflon, available at RV and Trailer shops as a 5th wheel hitch slick pad in a 10" disk for about $11. Or another good slick material that is 3/16" thick.
Next you disassemble the focuser and remove the old tension slider. Make a duplicate of this from the new material and drill the two holes as in the old slider, but drill them completely through. You can use the old one on top of the new one as a guide and drill trough both pieces. Then sand the thickness as required to have a nice fit, not too loose or it will allow the barrel to wiggle. But not so tight that it is hard to slide in and out. Sand a little and test fit it until it is just right.
This will make the focuser much more usable and less shift in the image when focusing.
The other mod, I did not take pictures, but I will explain it.
When you remove the focuser knobs and shaft, you have to remove 4 screws and a plate. Under that plate you will find a spring plate with two bent tabs that rub against the shaft to hold the pinion gear to the rack. These are too tight and should be bent to lessen the tension on the shaft. Making movement easier and smoother. You should also remove the old glue grease from the rack and pinion so you can lube it with good grease.
The rack is held to the focuser barrel by two small screws. Remove them and remove the rack from the barrel. Now cut a plastic strip to place under it as a shim. I used one of the many phoney credit cards that arrive in the mail all the time, you know the ones, they look like credit cards but are not. This seemed to be just the right thickeness. But you will have to test fit the rack to know. Now drill holes in the plastic strip so the screws will go through and reinstall the rack to the barrel. Re assemble the focuser and check the play in the rack and pinion. This shim should remove all the play between the rack and pinion gears. There is far to much as it comes from the factory. This will give you a nice accurate focus when racking in and out. There should be no free motion in the rotation of the focuser knob now. If there still is, shim it more until the play is gone. Now relube the rack and pinon and assemble for the final time.
The focuser should now feel much better and work a lot better. It will hold the collimation of the laser better too!
Have fun!
fblue's attachment for post 28880
Posted 12/30/2005 01:28AM #1
Floyd,
I have also modified this type of focuser for improved performnace. I found the Synta style focusers on refractors could be adjusted for reasonable action but they would not hold adjustment with any use. The set screws that adjust the slider were too small and pointed and the slider material would easily distort and flow around the point of the screw. It didn't take much weight in the tube to create a lot of slop in the adjustment. Eventually the set screw was buried so far into the slider there was no possibility of adjustment.
I removed the set screws and drilled and tapped the existing holes in the housing for a 6X32 screw. I also obtained some dog point set screws that have a very blunt dowel shaped end. I then modified the slider by carving a channel to carry some small washers where the set screws fit. The intent was to mate the washers to the end of the dog point screws and distribute the load over a larger surface of the slider material. The sides of the washers had to be ground down a little to fit better. (I suppose the slider could be drilled with a fostner bit to accept the washers.)
The end result is an adjustment that holds way better than the original and I can now use the heavier eyepieces and diagonal I have without ruining the alignment on the focuser. It's not perfect and still needs to be tweeked periodically but is much, much better than the original.
clear skies,
dan
