Error in Losmandy G-11
Started by Alex McConahay, 12/13/2004 01:41AM
Posted 12/13/2004 01:41AM | Edited 12/13/2004 01:50AM Opening Post
Hi all,
Anybody have any experience with Losmandy G-11 and a strange error I am having.
When I set up normally, things run pretty well normal. Then after two or three minutes of normal use, with the star staying right on the crosshairs of the reticle, the star starts to drift ever so slightly, and then there is an audible click someplace down in the right ascension shaft or worm-ring interface, and the star snaps back to the crosshairs. The total drift is about from one side of the crosshairs to the other (12 mm reticle eyepiece in a Celestron 9.25) The cycle repeats with a click-correction every 27 seconds (or so).
I can limit the amount of error by seriously unbalancing the scope--but there is still some drift and correction, and the click still happens at about the same rate.
Here is a picture of a star trail in M-42. You can see gradual drift-then correction, then shift-correction, shift-correction.
I should say that this picture was taken last weekend. So I brought the mount home, changed the right ascension motor and electronics. Same error after this fix. I then took the worm off, checked for dirt, grit, etc in both worm and ring, and then shifted the ring halfway around before resetting the worm gear. Still same problem. Did it all over again. Same error. Of course I adjusted for backlash, etc. each time.
This is one of Losmandy's upgraded worms. I have been using it for a while, although, I cannot remember taking photos with it yet--and that is always more critical.
Any ideas?
Alex McConahay's attachment for post 20766
Posted 12/13/2004 07:29AM #1
Wow, really tough problem.
How long was the exposure time in the image?
Some obvious suggestions:
- Take the worn cover off and run the motor. Either
watch the shaft or try to feel what it is doing.
- Take the motor off and run the worm shaft by hand.
see if it feels smooth or jerky.
- Take the motor off and run it. Feel the shaft
rotate and see if there are any jumps.
Posted 12/13/2004 03:54PM #2
If you have a Gemini, you might want to put a new CMOS battery in it, or at least take it out and put it back in. Last week my Gemini refuse to turn on. I was ready to mail it back for repair, and then I decided to take the battery out and put it back in. That fixed it. It must have reset the processor or something. You might also check the gear box. I had a bad one of those too and was causing my autoguider to over correct when it was autoguiding and I was getting oblong stars. If you can wiggle the motor on the mount, you probably have a cracked gear box cover.
Ralph
Posted 12/13/2004 10:20PM #3
You might want to ask this on the Losmandy Group on Yahoo, and maybe the Gemini Group over there as well.
Buck
