Digital Setting Circle Interface
Started by Glenn Gordon, 11/22/2004 05:01PM
Posted 11/22/2004 05:01PM Opening Post
Hi,
Can anyone tell me who manufacture an interface which would go between some US Digital Encoders I have on my scope and a planetarium program running on a palm pilot?
Glenn
Posted 11/22/2004 05:08PM #1
You might look here:
http://home.earthlink.net/~david.ek/digicircles/
Assembly required. I don't have one yet, but have been thinking about getting one. Perhaps others will comment?
Jim
Posted 11/22/2004 05:34PM #2
Orion used to sell the 'Sky Wizard CTI' which is a database-less version of the Sky Wizard computers.
JMI make something called the Software Guided Telescope, which uses a unit called a BBOX - unfortunately they want $209 for it...
http://www.jimsmobile.com/sgt_data.htm#Top
Plus you'd need an appropriate cable.
Maybe you can find a used one.
Posted 11/22/2004 05:53PM #3
There is a program called "2Red" which turns the handheld's default colors to red and black, so you can use it at night without sacrificing your night vision.
http://www.in2space.com/2red.html
-Glenn
Posted 11/22/2004 06:47PM #4
WE used a piece of window tint, the type you buy that does not glue onto the widow but just sticks to it. They come in smaller rectangles that act as Sun shades for the window of a car.
Worked great, just cut it to size and stuck it on the screen.
Floyd
Posted 11/22/2004 07:23PM #5
HI Glenn,
I think I have something like the "Black Box" interface. I will see if I still have it.
We can horse-trade off line if I can find it !! smile
David Simons
David Simons
Posted 11/22/2004 07:54PM #6
I have a Garman iQue GPS/PDA. Even when the display is set to red, an undersireable amount of the white backlight still leaks out around the edges. However, I've found that a piece of rubylith does a good job of dimming and reddening all of the light without disabling the touchscreen.
Allen
Posted 11/22/2004 09:46PM #7
I see I put up a bad link.
Try this one for the "2Red" program.
http://shop.store.yahoo.com/2sky-store/2red.html
-Glenn
Posted 11/22/2004 11:34PM | Edited 11/22/2004 11:37PM #8
Glenn,
I recently built a Dave Ek box to interface US Digital encoders to a Palm III. I use a program on the Palm device to point my scope that was written and is maintained by Doug Braun. The program works great and usually puts the object near the center of my 32mm EP.
The Palm program can be obtained from Doug's website at the following address:
http://palmdsc.dougbraun.com/
The Dave Ek box is not very difficult to build if you have basic soldering skills. I built the interface for less than $45. I would also suggest visiting Dave Ek's website for information on his interface. His website can be found at the following address:
I am still working on the description of my setup on my website. If you are interested in seeing mainly pictures of my installation, click on the following link:
http://home.earthlink.net/~steveswebuniverse/dscone.htm
I hope this information helps.
Clear skies,
Steve Murphy
Raleigh, NC
http://home.earthlink.net/~steveswebuniverse/index.htm
