james carter
North American Nebula NGC7000
Curved Spider Update
Started by mhosea, 05/26/2003 02:48AM
Posted 05/26/2003 02:48AM Opening Post
As I indicated before, I purchased a curved spider from 1800Destiny for my 7" f/6.7 Newt, which had a 1.3" ULS Quartz secondary in Protostar 3-vane spider. I also lowered the secondary obstruction to 1" because I wanted to try the smaller obstruction on for size. Despite the reduction in secondary size, the total obstruction increased by about 12% due to the wider vane thickness on the curved spider.
This dual change of course makes comparisons doubly difficult, and they would have been difficult enough given the amount of time required to install the new secondary and collimate. So, rather than talking about relative contrast between the two setups, let me just tell you how I like the new set up. I LIKE it. I really do. I took the scope out this evening and took a good look at Jupiter and saw some of the best views I've ever had through the scope. Again, I'm not sure how on-disk contrast compared, but the in-your-face, no-spikes view was clearly as good as any I'd had with that telescope, and it has always been a good planetary performer.
A word about the 1800Destiny spider. I ordered the smaller one, of course, for about $50 + shipping. It looked like the photo on their web site only somewhat better, actually, not as rough-cut as the picture made that one look. The paint was good and uniform, but a little gray I thought, but a quick overcoat with Krylon ultra-flat-black had that fixed up. The collimation system is simple and effective. My only concern with the design is that once you attach the secondary with RTV, removal and reinstallation of the holder from the spider may be a little bit tricky with the center bolt both loose and its Philips head inaccessible behind the secondary mirror. It may not be much of a problem, but we'll have to see when the time comes to clean the secondary. I would have appreciated smaller holes at the end of the vane, in fact just small pilot holes would have been fine with me. I was using 8x32 screws, and the holes were quite a bit larger (but I didn't measure).
The vanes themselves are, as you can see, thicker than quality straight spiders, but they aren't objectionably thick, and off-axis even the straight spiders will present a wider obstruction than their straight-on thickness. I was happy to trade a bit of obstruction for the stability, and the spider seemed quite stable and vibration free. Very likely somewhat thinner material would have sufficed, though, and I hope there are future options that will offer the same stability and freedom of vibration with somewhat thinner material.
IMO this spider is a great product and well worth $50. Some of you ATMs will realize that you could have made this yourself for $10 in parts and $100 in labor, but I think those numbers speak for themselves if what you really want is the spider rather than the experience of making it.
Mike
