Alan Adler's "cool.exe"
Started by go_ahead_ed, 02/07/2006 08:16PM
Posted 02/07/2006 08:16PM Opening Post
Hi All,
I've been playing with Mr. Adler's cool.exe program (Jan. 2002 Sky & Tel.) again and I just noticed something...The program lets you adjust the cooling fan's output using a FPS or feet-per-second value. However....most of the cooling fans I've seen (on websites and in magazine ads) are rated in CFM or cubic-feet-per-minute. If I divide a CFM value by 60 to get a cubic feet per second value it looks like I'll need Pratt & Whitney Double Wasp radial engine to drive a fan at the necessary rate shocked
That being said, the 120mm fan I currently use, rated at 53CFM, seems to work just fine so this question is just out of curiosity I guess...
Ed
Ed Moran
Equipment Forum Moderator - Two of Five
Posted 02/07/2006 11:13PM #1
Probably mean to put it in CFM and it is an error?
Posted 02/08/2006 03:15AM #2
[QUOTE]Ed Moran said:
Hi All,
The upside of that is it would just sound SOOOO awesome. *evil grin* There ain't much that sounds as good as a big round motor.
-Kevin in Indy
Kevin in Indy 8)
Posted 02/08/2006 01:10PM #3
I'm guessing that it's accurate; he's talking about fan speed. You could convert by using:
FPS (velocity of air passing through cooling fan, in feet per second; note this is NOT a unit of volume)
12 inches per foot
Area (of cooling fan in square inches)
CIS (cubic inches per second) of air that the fan is pushing in.
Then you can convert CIS to CFM easily: (CIS * 60) / (12^3) = CFM
