HI all--
Finally got a decent night at my home in Petaluma, 39degF, clear and calm, LM 5, seeing decent, maybe 7/10. Looked at a few galaxies near the bowl of the big dipper, new ones for me, in my 16"; eyepieces a 16mmT5 and 11mmT6. I was happy with the detail I could see despite my semi-suburb location.
ngc 2950, 1 deg W of 29upsilon-UMa, small, bright, almost stellar, maybe 1 arcminute wide.
ngc 3079, 8 deg W of beta, very nice! edge-on, extended 135deg about 8 arcminutes, central bulge, hint of dust in AV?, mag 12 or 13 star embedded in NW tip.
ngc 3359, NW of alpha, a 2:1 oval, maybe 7 arcmin long, quite faint. In the 11mm detected a central bar. (I was very happy with that observation. Not knowing the galaxy beforehand,I came in and checked the DSS image--it's a pretty dramatic SB type.)
ngc 4041 and 4036, roughly 5 deg NNW of delta UMa, a lovely pair aligned north/south. about 20 arcmin apart, 4036 is to the south, elongated 80 degrees, 3:1, bright core, about 4 arcmin long. 4041 is of similar brightness but rounder, more diffuse.
ngc 4605, 6 deg NNW of epsilon, magnificent! elongated 120 degrees, 3:1 or maybe 4:1, lens shaped, 7 arcmin long, and definitely fatter at its western end.
ngc 3738 and 3756, a nice pair, arranged nw/se, in line with the mag 6 bowl star sao 28064 (W of gamma). 3756 is larger and dimmer, more elongated, about 2:1 roughly N/S, mottled. 3738 brighter and rounder. A nice chain of 5 mag 9 or 10 (?) stars links them in a graceful arc.
Well then some high clouds blew in from the south, and I finished the night with a good view of Saturn at 360X, the crepe ring very evident, cassini a solid gap all around, and nice shading on the orb itself, little enceladus at western elongation. Overall a great 2 hours of observing.
Best regards
George
Best regards
George
George Golitzin
