Vintage Sears Discoverer 60mm
Started by kshouse, 05/21/2009 07:41PM
Posted 05/21/2009 07:41PM Opening Post
Hi all,
I thought I'd test a newly acquired Sears Discoverer 60mm lens last evening.
But first- when cleaning it last week, I found that the two elements in the lens had no spacers of any kind. That seemed peculiar based on all the 60mm lenses I used to take apart, but then you never know. I put the cleaned glass back together- glass on glass.
So last evening I saw a nicely focused Saturn surrounded by a defocused "ghost" disc of light about 5 times the dia. of the planet. The ghost disc would focus or defocus. At only one place in the FOV would the focused Saturn be centered in the disc, (and it wasn't in the center).
Am I correct that the ghost is a result of not having the two elements properly spaced? Is that spaceing critical? Any suggestions as to what I should use? Thanks!
Posted 05/21/2009 08:24PM #1
I would venture to guess that the last owner "cleaned" the elements by removing them, and has placed one or both of them in backwards. That would give you the ghost halo.
Rolando
