John Greenlee
Before and after
Stellarvue M7 Mount
Started by McDaniel, 12/24/2007 03:16PM
Posted 12/24/2007 03:16PM Opening Post
Hello,
Does anyone out there have a Stellarvue M7 Mount?
I would be interested in any information or user reports about them. They look great from what I can see from the Stellarvue web site. They are also described as "waitlisted," but there is no estimated delivery date on the waitlist page.
best regards,
Steve
Posted 12/29/2007 02:07AM #1
Hi Steve,
The Stellarvue M7 is the first mount I have seen from Vic that looks competitive with Tom Peters' DiscMounts, which use a similar ball bearing construction. I own both a DM-4 (carries AP130) and DM-6 (carries TEC160). They are both wonderful mounts - smooth and extremely stable. That said, there are times that the adjustment locks on the M7 would be most welcome, such as when changing from a Plossl to a 41Pan. :S
Note that the -4 and -6 in the DiscMount numbers refer to the bearing surface diameters in inches, so the 4.5" azimuth diameter of the M7 is actually closer to the DM-4. However, neither DiscMount uses a counterweight, which limits their ultimate weight carrying capacity because heavy scopes skew the weight distribution on the azimuth bearing surface.
Good luck,
Milt
