Horsehead Nebula
if someone makes them, will you come?
Started by yahganlang, 02/04/2006 09:52PM
Posted 02/04/2006 09:52PM Opening Post
For the past months I've been experimenting with fabrication methods for large, telescope-scale gradient index lenses. These would be ultrathin, ultralight, and if they became available relatively cheaply (you couldn't get one now unless you were prepared to slap down a six or more figure sum) the question is whether the refractor-oriented community might be willing to try them out, or would they be more likely to say 'thanks but no thanks' and stick to the tried-and-true, despite that meaning being limited to smaller apertures (remembering that I'm using reflector apertures as a benchmark)?
Wouldn't you like to be able to stare the mirror boys right in the face and say, 'analyze this!', aperture wise? Or maybe you just LIKE top-heavy?
A refractor is a refractor, regardless of lens type- so I'm curious to hear your thoughts on the matter.
Jess Tauber
Posted 02/04/2006 10:29PM #1
Jess, I think that if you could make an affordable large diameter grin lens that performed comparably to a traditional lens, the amateur community would beat a path to your door. Performance would mean everything though. A 14 inch objective lens would be swell, but if it couldn't form crisp images....
Good luck! Jim
Posted 02/05/2006 03:04AM #2
Are you talking about a lens in which the index of refraction for each element changes with radius from the center?
What would a 8in F5 lens cost?
Posted 02/06/2006 04:53PM #3
Grin only adresses one aberration - spherical. How do you propose to adress chromatic aberrations over a very large spectrum range?
RC
