Iris Nebula
not enough inward travel for focus
Started by csa/montana, 11/19/2006 02:03AM
Posted 11/19/2006 02:03AM Opening Post
What is the reason an eyepiece cannot reach focus, because of not enough Inward travel? What can be done to remedy the situation?
Thanks, Carol
Posted 11/19/2006 11:45PM #1
Couple other ideas:
If its a 1.25" eyepiece in a 2" focuser that has
trouble, you can get various 1.25" adapters where
the eyepiece sits very low or even inside the
2" tube.
If you only need a couple millimeters, you can
put clear or UV filters on the eyepiece. You
will get about 1mm effective in-travel per filter.
If you need more than a couple mm, you can make
yourself a filter with a thick glass window, but
it is more work.
