james carter
North American Nebula NGC7000
What's it called?
Started by mrvolvo, 05/21/2010 03:29AM
Posted 05/21/2010 03:29AM | Edited 05/21/2010 03:30AM Opening Post
Please refer to the attached photo. What is the correct name for the flip-lever screw that allows you to tighten a TeleVue clamshell. I'm working on a project where I need a commercially available example of this type of fastener but I can't find it because I don't know its correct name. Any guesses?
mrvolvo's attachment for post 51024
Posted 05/21/2010 05:22AM #1
I thought it was a quick release, but it's not.
Good question, I will keep looking.
John
Posted 05/21/2010 01:02PM #2
I don't know that this is a standard design. You could call Televue and just ask.
Posted 05/21/2010 01:28PM #3
I suggest you browse the McMaster-Carr (mcmaster.com) web site, they have pictures and names for all sorts of obscure mechanical components.
Posted 05/21/2010 03:23PM #4
Thomas Holst said:What is the correct name for the flip-lever screw that allows you to tighten a TeleVue clamshell?
A similar device on another company's clamshell ring, which is a knob without the lever, is referred to as the "adjustment knob."
Posted 05/21/2010 04:07PM #5
If the rotating portion is threaded, I'd call it the lock down screw (wingnut type) However military nomenclature asside. I'd send the photo to TeleVue and just order it that way.
Steve
smile
Posted 05/22/2010 02:51AM #6
Perhaps more readily available (can be sourced locally at a Hardware store) is a threaded post with a sliding cross-rod (for tightening leverage), as commonly used for bicycle seat height adjustments without tools, etc. Performs the identical function as the TV Batwing screw (i.e. non-tool adjustment in zero-clearance situations).
Posted 05/28/2010 07:30PM #7
I expect Mal Speer at Malco Precision Products
would know.
http://www.malcoprecision.com/
