I think the used telepod head I just bought may be broken.
When I turn the telescope counterclockwise on the azimuth plane the telepod head has a tendency to unscrew (not from the tripod itself, but to disassemble the top of the head from the part of the head that is screwed to the tripod).
Any ideas of how to fix this? Also, the tension knob meant to control azimuth rotation is also apparently broken--it has no effect. I disassembled the mount to see if I could fix this issue and a small bit of plastic fell off the tensioning bolt itself, which I imagine used to be a part of the bolt when it was working.
Any ideas how to fix this? I tried greasing the contact areas that the head is supposed to rotate within rather than unscrew, but that hasn't really helped.
Thanks in advance.
Thanks in advance.
