Hi - I've found that adding the SV "multi-use plate" between the mount and rings lets me adjust the position of the scope so it balances properly. Otherwise, you might check with SV, the newer ATs use a single mounting ring that may alleviate the problem.
Re: balancing dec. axis on AT1010
Started by karimb1, 02/02/2003 04:31AM
Posted 02/02/2003 04:31AM
Opening Post
Posted 02/02/2003 10:33PM
#1
Bob, I have the AT1010 on the same mount (M4), a 2" diagonal, and I use eps ranging in weight from orthos to a Panoptic 35. With the extra plate the rings can be mounted closer to each other, and in a more forward position relative to the mount; this is just enough to give the balance adjustement range that is lacking in the standard setting. If you rebalance between eyepieces, no tightening at all is needed.
Funding Member
Sponsors
- Matsumoto Company
- astronomy-shoppe
- kwtelescope
- Astromart Customer Service
- Vernonscope
- FocusKnobs
- CarbonScopeTubes LLC
- AstroMart LLC
- RemoteSkies.net
- Waite Research
- SellTelescopes.com
- OMI OPTICS USA LLC
- BW
- APM-Telescopes
- Anacortes Telescope
- BBLABS LLC
- Desert Sky Astro Products
View all sponsors
