Radio Astronomy
Started by chris brown, 01/17/2003 06:01AM
Posted 01/17/2003 06:01AM Opening Post
Have any of you fine folks had any experience with radio astronomy? I have heard that you can "hear" Jupiter at low frequency AM wavelengths...
Chris Brown
There's something on the Moon! 8O
Posted 01/17/2003 09:40PM #1
Yeah, I've had a little experience with it.
Check out
http://radiojove.gsfc.nasa.gov/
Posted 01/17/2003 09:42PM #2
Chris,
While the standard AM broadcast band may be possible, higher frequencies will work much better due to lower noise levels and interference. I believe the best range is in the 18Mhz-30Mhz range of a short wave receiver with decent sensitivity. You'll need something much better than a standard ferrite rod or short whip antenna also. Try searching "Radio Jove" for more info. The radio Jove receiver works close to the 20.0Mhz time standard frequency in Boulder, CO.
I have a Sun/Jupiter setup using my amateur radio gear, but I haven't tried it out yet. Another place to search, if you're really interested in radio astronomy, is SARA. It's the Society of Amateur Radio Astronomers.
--Lonnie, WD8MCY
