Orion Astroview 90 vs. Homebuilt 6” f/8 Newtonian w/Parks Optics
OK, here’s the comparison I promised, right on schedule (the weatherman finally called it right days in advance!)
First of all, a few comments and report on seeing conditions. Thursday was a great night to do this test since both Saturn and Jupiter were well placed in the sky and seeing was excellent.
It would be unfair not to preface this with a comment on the optics in the reflector. Parks makes excellent production mirrors, better than most. If one is to make a decision between an Orion and similar 6 inch Dob and the AstroView, I don’t think the comparison would be quite the same. I wouldn’t expect the same quality from Orion that I expect from Parks. That being said…
To begin, I used a 12.5mm Ortho in the Newt and a 9mm Ortho in the AstroView and aimed at Saturn. This yielded powers of 98 and 101 respectively. Seeing was steadier in the AstroView, although both were above acceptable. There were LENGTHY periods of steady seeing in the smaller aperture scope, and this provided more opportunity to view detail. Not a surprise. Steady moments were rarer in the Newt, and the glare from sheer brightness washed out some detail.
The South Polar Region yielded more detail in the 90, it was just easier to see. A neutral density, colored, or polarizer filter would fix the obscuring brightness for larger apertures such as 6 inch but for this test I used no filters. Cassini was sharp and clear in the 90, and the same was true of the 6 but only during moments of steady seeing. The shadow of the globe on the back of the ring system was easier in the AstroView as well. But in those good moments, detail was a bit sharper in the 6. The South Equatorial Belt was obvious in both scopes. The view in the 6 was pretty bad in rare moments when the seeing acted up. The 90 had no such problems.
Then I switched the 9mm to the 6 incher, and put a 7mm Ortho in the AstroView, yielding 135x in the Newt and 130 in the 90mm. Now the Newtonian started to do its stuff due to the reduced brightness. Still, seeing was a factor but no problem for the AstroView. At this point it was a very close contest, in fact, pretty much strictly a matter of taste. The brighter image in the 6-inch was now at a more comfortable level than the AstroView, which was a bit dim. Still, no problem making out lots of detail in either. I’d say I preferred the brighter image in the 6 at higher powers, but preferred the steadiness of the image in the 90. I could see the same amount of detail in either, both provided excellent views.
continued...
continued...
