Ruben Tommasi
Andromeda Galaxy (M31)
Barlow vs.Powermate
Started by paulsky, 09/20/2007 09:30PM
Posted 09/20/2007 09:30PM Opening Post
Hello,
Which is best for a newton telescope with small focal lenght(F/6)? Is the Powermate an instrument very similar at barlow lens?
Paulo
Posted 09/21/2007 03:31AM #1
See if you can borrow one of each within your group or club, then make a decision.
TeleVue site should have an explanation of the difference. Something to the effect that the second group of lenses bring the light rays into a parallel path, eliminating the tendency for some light cutoff. PERSONALLY, the powermate does do a better job with the extra set of lenses, but costs more.
You might also try the ASK AL section, I KNOW there is an explanation of the difference somewhere on the site.
Posted 09/21/2007 10:15AM #2
Paulo martin said:
Hello,
Yes.
Advantages of the Powermate:
-no vignetting at all of some (rare) eyepiece types, like eyepieces with a field stop close to the limit of the barrel or TV Plössls. Mind you, the effect is usually very mild even with a regular barlow.
-keeps eye relief constant - a barlow will increase the eye relief of long focal length eyepieces considerably, rendering them uncomfortable.
-throws the new focal plane out just enough (as much as the height of the part sticking out of the focuser) without requiring a large insertion depth, like e.g. the excellent TV 2x barlow. That means you rarely require extra focuser in- or out-travel; if things come to focus without the Powermate, it will with the Powermate.
-on some models, the magnification does not depend critically on the placement with respect to the focal plane (and thus indirectly on where the focal plane of your eyepieces lies with respect to the end of the eyepiece barrel). That's usually a more important consideration for astrophotography, though.
If none of this matters, then a regular barlow, something like a TV 2x barlow, is usualy more interesting (all these things don't come free: there are more elements and the powermate is more expensive).
But often, one of these things does matter, in particular if you are planning to barlow longer focal length eyepieces (over 20mm) or can't stick the longer TV barlow in the focuser in some conditions.
