Leica 8x50 apparent field of view?
Started by nils_schoultz, 01/22/2004 06:05PM
Posted 01/22/2004 06:05PM Opening Post
I'm thinking of buying a pair of these now that they are being heavily discounted but for me the apparent field of view is one of the most important stats for a binocular and I can't find it anywhere. The real field of view is 115m at 1000m or 6.6 degrees, but I know of no formula to convert to afov. Can anyone who has a pair of these describe what the view is like? Many thanks if so.
Posted 01/22/2004 08:13PM #1
Nils,
Since you are using metric measurements I assume you are not located in the USA? If so what is approximate discount price in Euro/pounds?
I don't have any Leicas myself but I know they make very fine binoculars. However, I aslo know that you can spend a fraction of what you'd pay for a Leica and still enjoy excellent astro binoculars. The Pentax DCF and PCF series comes to mind. For astromy use I'd recommend 10X50s instead of 8X50s if you can handle the higher magnification. Higher X and 5 mm exit pupil will give you a darker sky background and show a bit more detail. A 10X bino with 5.5 deg FOV will give you slightly wider 55 deg APFOV.
I regularly use an Oberwerk 12X60mm(US$109) without a tripod. But have been thinking about getting the more compact roof prism Pentax DCF SP in 12.5X50mm for traveling. The DCF SP is the top of the line Pentax. It's waterproof, fogproof, has phase coating and close focus to ~3 Meter. It's available in the USA for about $600. A 12X50 Lecia easliy cost twice that.
Erik D
PS. KJ, I did the same calculation but came up with slightly less: 52.8 deg APFOV for the 8X50 Leica. :-)
